Rix
100 TW
Big_Lez said:Offroader said:Jasonjm said:Offroader did that shinko 3 inch x 18 tire fit on thr stock sur Ron rim? No rubbing on the sides against frame?
Good quesiton, I didn't actually try and see if it would fit. Considering a 3.5" shinko 241 tire just about fits, this should fit no problem.
It doesn't seem to be all that much wider than the stock tire also.
I liked the stock Sur-Ron tire but it wore out way too quickly in the rear. Maybe 400-500 miles to completely wear down. The stock tire also seemed to break traction easily, I believe it just was not wide enough for good traction and I was easily always spinning it off road and ripping up grass and dirt. The shinko 241 size 2.75 tires are not designed for the rear or rear traction and are designed for the front and they have harder tread compound and not as deep knobs.
The shinko 241 3.00 size tires I found offered really good traction in the rear. I used a 17x3.00 241 tire on my 8 KW hub motor bike and it had very good traction off-road. It is yet to be seen how my 18x3.00 tire holds traction on my mid drive Sur-ron. I believe it should hold up really well considering it is wider, designed for rear traction, soft compound and long knobs. I run about 12 PSI in it also to help with the traction.
I'm more thinking how it is going to go fitting the 18" tyre on a 19" rim - can't wait to hear how you go though - if so the 3.0 x 18" will be my next rear tyre.
Off road will have to re-lace with an 18 x 1.40 or 18x1.60 rim.
