Ecyclist
Actually, crumbling rubber mounts is the big part why you have a noise problem. If you think about it, you will see it.mechanistic said:That broken rubber mount is not making that sound.
I wasn't suggesting the mounts themselves were causing the sound. (Hadn't even occurred to me...)
I was going with your instructions to look around for some unintended shift or movement...
Other possibilities for unconstrained movement are these types of dual-sided threaded stacks:
No clinch means no preload torque (for retention, load-spreading, etc.)
Plus, the unsupported sections can fail under shear.
