IMHO the BC makes a great base for an ebike kit. The BC is very strong and has very standard dimensions. 100mm front,, 138mm rear dropout spacing for hub motors, standard 73mm BB width, and lots of clearance for BB mounted mid drives, lots of tire spacing and can handle a wide variety of 26, 27.5 or 700c wheels. The overall geometry is middle of the road, it's supposed to be an adventure bike so it's designed for the combination of both road and trail riding.
What to watch for ... there isn't a lot of front chainring clearance. It's normally limited with a single ring to about a 38t (but duals and triples give you a lot more big ring capacity ... and if you do go with a front derailleur you'll also need to pay close attention to the offset). The front fork is very rigid (required for racks/bags) and does transmit quite a bit of shock so running softer front tires helps a lot with hand comfort.
