Hello,
I am a 33 yo frenchman living in Switzerland. I have converted a antique swiss military bike to electric propulsion.
Swiss military bikes were designed and first produced in 1905 until 1993! A registered number of more than 68000 of them have been issued to the swiss Armee. They are fairly affordable on the second hand market. This particular one is from 1937 and has the frame number 15754. I got it for 320chf (=320usd). My plan is to use it everyday to go to work instead of my current non electric powered bicycle.
I used the following parts:
36V 20 ah battery: https://www.aliexpress.com/item/Fre...2614449803.html?spm=2114.13010608.0.64.pybEW1
Eunorau (bafang) 36V250W front roller brake hub motor: https://www.aliexpress.com/item/DGW...2692480353.html?spm=2114.13010608.0.77.pybEW1
Eunorau (bafang) converter and display: https://www.aliexpress.com/item/Bic...2706430067.html?spm=2114.13010608.0.72.pybEW1
Before:
During the Build:
Old and new front hub:
I had to do a cold spacing on the front fork. I had to stretch the spacing of the front fork to 135mm in order to have a final spacing of 101mm. This is because the steel of the fork is elastic.
That's sexy me lacing the front wheel:
After:
I really like the Bafang LCD display. It display very useful information while integrating well with this old bicycle:
The PAS sensor was installed by gluing the magnets directly on the sprocket. It works perfectly and it is very discreet:
The 36V 20ah battery fits perfectly into the frame bag which was originally designed to carry ammunition!
Sadly it was short lived as my first ride either fried the motor or the controller. I am researching the topic right now to try to find the best possible solution to put it back to the road. I hope the community can help.
The seller wants me to send him back the motor and controller. I however would like to test each component independently.
Here is what happened: I went for a 15 mins ride where I let the bicycle carry me at max speed with no pedal power when it suddenly came to an halt. The display was indicating a current of 40A when riding. With a fully charged 36V battery reading at 40V+ that means 1600W into a 250W motor! The controller is supposed to limit the current to 15A but when I contacted the seller, he told me 40A was normal :? .
After trying everything I could, I came to the conclusion that either the controller or the motor is fried. My plan to solve this problem asap is to order a new controller and motor. Should I order a bigger bafang 48V500W BPM front hub motor because it should be more robust? My goal is to have high torque and max speed around 30kph. The bike is extremely heavy (33kg). I live in a steep area with many hill. I need something reliable and strong. I want to occasionally carry my child in a trailer.
I thought buying a assorted 36V 250W motor and controller would give me reliability. Now I discover that it is common for bafang motor to just fry. Do you know what would be the best reliable alternative (motor + controller) for this project? I'm really in love with the Bafang display and control and hope to retain it but if it proves to unreliable, I will have to choose something else.
Thanks for reading and I hope you can give me some answers!
Before:
During the Build:
After:
