batteryGOLD
Hi there battery fanatics!
I came here to show you a TESLA battery module at detail showing that cooling crazy design!
Is that just a mediocre engineered cooling system, expensive and complex design production? maybe polemic.
Why to have that crazy cooling system at lateral of cells with minimal surface area contact? According some studies, the heat transfer is not good around cells. For similar propose just need fan extractors at battery module case, air circulation will be more efficient than that and very low cost production!
The real cooling will be at top and bottom cell plates. Top and bottom of 18650 is connect inside by a conductor at center of cell and at the end of the roll.
As you know a good electricity conductor is as well a good heat transfer medium.
Soo positive top is connected to center of cell, and heat shout be extracted from there by the conductor and bottom as well, with plannar liquid circulation top and bottom plates. similar to "tab cooling" concept
Just saying..
Anyway, here are the pictures
Just saying..
