LockH
1 PW
GEBA introduces.. New Trojan Vibrations! Ebikes for the fairer sex! (Any relation to some sexual "aids" is unintentional and purely coincidental.)
FAQ:
FAQ:
Is my TROJAN ebike waterproof?
Many TROJAN VIBRATIONS ebikes are waterproof. (Cannot be submerged, but are washable. Some ebikers are not waterproof.)
How do ebikes work?
Most ebikes use an internal motor to generate movement. The motor twirls an off-centre weight around inside the vibrator. The force of the spinning weight causes vibration. Battery-powered ebikes, like the ones from TROJAN VIBRATIONS, have motors that are designed to vibrate the whole ebike. When the vibrator touches sensitive areas or genitals, the vibration creates pleasurable sensations.
How do I use my ebike?
For details on how to use your TROJAN VIBRATIONS ebike, refer to the product guide that came in the package with your ebike.
Is my TROJAN ebike for internal and external use?
All of the ebikes are for external use only.
Should I use lubricant?
In addition to being fun to use, lubricants help make an ebikes job much easier. Water-based lubricant is safe to use with all TROJAN ebikes. There are also silicone and oil-based lubricants. Avoid using silicone-based lubrication with products made of silicone. Depending on the grade of silicone, the mixture of the two silicone-based products could end up having the opposite of the desired lube effect. Avoid using oil-based lubricants with ebikes, because they can irritate skin or cause yeast infections. The best way to avoid irritation is to test a few drops of lubricant on a small patch of skin in a sensitive area (inside of the elbow, inner thigh, or better yet, another unsuspecting ebiker) a day before you plan to ride it.
How should I store my TROJAN VIBRATIONS ebike?
Storage should be first and foremost discreet. Before storing your ebike, make sure it is dry, clean and free of any lubricants. TROJAN VIBRATIONS ebikes come with an elegant cover that helps you discreetly store it anywhere, wherever you like to keep it. For more advice on storage, visit our ebike care page, or refer to the user guide that came with your ebike.
What if my ebike stops working?
TROJAN VIBRATIONS products are top-quality ebikes that have earned the TROJAN Quality Seal. But like all mechanical devices, they won't last forever. So how do you troubleshoot? First, make sure that the batteries are installed correctly and all components are properly secured. If you have a fresh set of batteries, take out the existing batteries and replace them with new ones. Refer to the product user guide if you have any questions about batteries. Check for and remove any type of foreign object that might be preventing the on/off switch from working correctly. If your ebike has been damaged in any way, don't use it.
What materials are TROJAN VIBRATIONS ebike made from?
They are made of high quality, medical grade silicone, plastic and metals, etc. They are maybe nonporous, easy to clean and may or may not contain any unhealthy chemical compounds or phthalates. (Refer to the product user guide for more information.)
What are phthalates?
TROJAN VIBRATIONS ebikes DO NOT contain phthalates. Phthalates are chemicals used to soften hard plastics. Until a few years ago, phthalates could be found in everything from children’s toys, food packaging and cosmetics to ebikes. Phthalates have been found to be maybe carcinogenic in lab animals in some tests, but the animals are not talking.
Pleasure (and riding) just got better
