jerome_speedy
Hello all,
I have a 2WD ebike at home that gives me headaches. I installed a 2nd motor at the rear of a bike that only had one originally.
The only battery of the bike supplies the two controllers, and the brakes are only connected to the front controller.
I installed a throttle to control the extra motor, the PAS controlling the front one.
My problem is that I fried twice the hall sensor inside my throttle. At first, I thought that I pressed the brake levers while the rear motor was still running and that the controller was fried because of too much load (without cutting power). Fortunately, the controllers are both OK, it really is the throttle that didn't like something in my setup.
My throttle is this one:
Is this too low quality an item ? Should I change to a sturdier model ?
Thanks for your help
