Burtie said:
NeilP said:
... to see if this board does actually achieve what it sets out to....
This board sets out to enable the commutation timing of a sensored BLDC motor to be adjusted. I think we have seen plenty of evidence to show that it achieves that.
Dont confuse this with 'The aim of this board is to make Neils bike go faster '
We are aware that your bike doesn't go any faster, you have continually reminded us of this over the last several pages.
Burtie
Sorry Ian, I am not having a go at you, may have phrased that badly. It obviously does what it is intended unloaded, I have more than shown that to myself and others in the video clips.
Maybe what I should have said is I want to see if it can make this particular motor type go faster in road conditions.
I always thought the purpose of this timing adjustment was exactly that, to increase road speed, maybe I have misunderstood. So maybe I am missing the point of what this board was for. I thought that the total point of this board was to increase the top speed in road conditions.
Burtie said:
The aim of continually adjusting the timing is to help keep the motor operating at its maximum efficiency, or maximum performance
Burtie
Maybe I mis understood the use of the word 'Performance' I just jumped in and assumed max performance as opposed to max efficiency would mean more speed
As a tool to show that timing advance/Field weakening theory works it is great. it does that brilliantly, you have implemented it all very well with an easy to use and setup piece of kit, not knocking or denigrating your work in any way.
The bike I have is not a 'real' bike it is a test rig built solely for seeing what results I can get from the board. I do not need the test bike, the board, spare controller or any of it. I am doing it all merely in the interests of experimentation and trying to see if I can show real world results with a hub motor of low pole count.
If I get it to give me increased road speeds, it will only encourage more people to buy it and get you a few more sales.
Even if I can't get it working to increase road speed as I expected it too, it may at least show what is causing this motor to not increase speed further which may lead to you being able to at least give advice to new buyers as what will show a speed increase and what will not.
So not knocking your work in any way, just trying to get to this motor to go faster in real world conditions with the board. it goes great unloaded just loaded something is limiting it and until I can try another controller, can only assume that it is the controller that is the problem. I never once said the board was the issue here
