Coloradogoose
- Joined
- Nov 4, 2019
- Messages
- 4
I've been doing research for a while now and I'm hoping for a little advice because my head is spinning. I would like to use an electric motorcycle for commuting however I have a pretty long commute that requires highway speeds for a few miles. I've looked at the options to buy a bike, but they seem to get pretty expensive once they have enough speed and range to meet what I need. I have a rolling chassis for a scrambler that I could build into an electric motorcycle, but I'm not sure if that is the better route. I'll lay out what I need below, as well as some info about the current chassis that I have, and then finally the questions that I am hoping for some guidance on.
What I need from a bike:
I am in a very rural area so I need a minimum 60 mile range with about 10 of that at 60-65 mph and the rest at 30-45 mph. (I can't avoid 5 miles of highway each way. After that I can take backroads). No charging options at work either.
Able to cruise at 60-65 mph for 5 miles at a time
More concerned about top speed up to 65 mph than I am about acceleration
Comfortable for a 1/2 hour commute each way
What I'm starting with:
I have a rolling chassis with 18" wheel/tires installed. It's from an old small-displacement dual-sport and I've done a fair bit of work to get it where it is. All it needs is something to make it go. Everything else is there already. The motor that I pulled from it is trash and it was not a stressed member of the frame. I was planning to drop in a more modern ICE motor but would love to explore electric. Because the wheels are built already I would prefer not to cut spokes and re-lace the rear wheel with a hub motor, but if that's the best way to go, I'll do that. The swingarm is 200mm spacing, so a QS hub should bolt right up.
I have a fair bit of knowledge, skill, and access to tools to customize things. I have a 3D printer, mig welder, small 3-axis CNC mill/router that can do aluminum as well as CAD skills, plasma cutter, and a manual mill that can easily handle steel. I've not built any sort of electric transportation before so I'm planning to build an e-bike this winter as a way to learn a little more about things. I will probably build my own spot welder for making batteries and unless there is an off-the-shelf battery that I can afford I will plan to build my own for the motorcycle.
My questions:
Do I gain little to nothing if I do this myself over something that's already made? I've looked up a lot of e-motos and seriously wonder about options like the Super Soco TC Max, or other bikes that I haven't stumbled on. Any other suggestions for pre-built bikes? I'm not attached to building this myself. I always have enough projects going that I can focus the energy elsewhere if there isn't a really compelling reason to build it myself.
Which brings me to... Is this even worth doing? I have pretty lofty needs compared to city commuter bikes. Am I going to end up spending $10K to get something worth riding?
If folks think I should go the build route... what suggestions for motor and battery specs should I aim for? I can read all day about the motors but I'm hoping for some input from people with real-world experience with this stuff. Mid-mount vs. Hub? Battery requirements? Controller suggestions? Charger suggestions?
I appreciate the time that anyone takes to respond!
My questions:
