After three Trampas with Channeltrucks i want to build one with the Skatetrucks.
My aim is to get as light as possible, i would like to use this Board in skateparks and for jumping.
This is the Board:
Trampa Holypro 15degree in 11Ply with Ultimate Trucks and Superstar Hubs.
http://www.trampaboards.com/15-holypro-trampa-deck-on-10mm-titanium-trucks-superstar-wheels-ratchet-bindings--024-mountainboard-p-12326.html?selector_id=11868&qty=1&nochange=1&show_me=1
I added some green DohDoh Bushings for better steering.
http://www.trampaboards.com/green-doh-doh-bushings--over-sized-washers-set--93a-shore--soft-p-640.html
I will use the new Innova 7inch Street Tires.
http://www.trampaboards.com/innova-inline-street-tyres--7-inch-tyre-p-12772.html
compared to the really light Primo Alphas you will save 65 gramm per tire.
I started to machine some new Motormounts which fits direct on the 9.52mm Axle.
They get really light with less then 90gramms:
Compared to my latest Channeltruckmounts i can save about the half of the weight. For this board i will not use any braces.
Mounted on the trucks:
The mounts are glued to the axle and also screwed, i had to spotface the axle with 1mm depth and 7mm diameter.
Redesigned the 60 thooth sprockets with bigger cutouts:
If you compare to the latest sprockets i can save nearly 30% :
Will keep you updated.
Hang Loose
Jenso
This is the Board:
Hang Loose
Jenso
