So I'm having major troubles trying to get my CAv3 & TDCM sensor to play nicely together and give me a good PAS experience. Frankly, to get much of any PAS experience currently. Originally I had some amount of responsiveness, although it wasn't very good & pulsing a lot, but lately even going back to previous known settings (I save every write to it's own file before writing) I don't get anything.
I see a voltage & Nm change in the CA Live Data monitor, but I'm not getting any power assist when pedaling, nor do I see the little left/right bars going up at all. I've been through section 5.7 of the (un)official manual a few times, including a vaguely accurate torque scaling as per sub-section 13 on TDCM sensors. I just did a data logging on my commute today, and saw all 0's for the RPMs & Torque values. Is there something else to check? Other settings? Should I put in a shunt and use a multi-meter to monitor something? I could get the tools to pull out the sensor from the BB to check something, if that's necessary.
