Hi ES,
First of all, I’m new to ebikes and motor technology please pardon me for my stupidity.
I have been searching, reading for the past months trying to figure out how much amps a motor can actually take.
So far, what I have learned is amps/torque is what heats up the motor.
1. So I can pump as much amps as I can, as long as the motor stay cool? ( cooling mod, ventilation..)
2. My controller is pulling 80amps from battery during acceleration, and ~30 near top speed ( within 90%). So if I swap to a 150amps controller, same condition same load, the controller will pull 150amps during acceleration then ~30amps within 90%?
If these are true, then does it mean that if my motor will do fine with any bigger controllers, as long as condition and load stays the same ( to pull 30amps near rpm).
So what do I look for? I want a bigger, beefier controller.
I’m running 72v, the rating of motor is unknown.
80amps controller, after a long ride with heavy load, motor stays warm.
Thank you
Edward
Edit: it is a hub motor
Thank you
Edward
