I apologize if this information can be found from this thread or the OSF wiki, but my searching yielded no result.
I know that the stock firmware motor can be ebabled without a display by connecting the battery voltage wire to Vin wire. But is this the case also with this configurable OSF for all displays? I assume I would be using the version for stock displays so I could tune it with the Java configurator.
My idea is to build a minimal motor system for my gf. I'd want to eliminate any wires that are not necessary and just enable a fairly low power assist working always when the battery is on. If I remember correctly, the stock fw defaults to max assist level when working without the display, so that is not a workable solution, rather I need to be able to tweak it to be a safe low power system.
