I have been messing around with a cheapo 72V Hua Tong 15-FET controller to see how well it spins my Turnigy 80-100 outrunners. My thinking is to use it as a replacement of my Kelly if and when it blows. In any event I was spinning the 130Kv stock wound motor under no load to see what the max rpm of the Hua Tong was. It got it up to 7770 rpm before it lost sync (note at 1:40 in video that the current jumps to 10A right when rpm hits max), which works out to just over 54000 eRPM. Pretty good for a $37 controller. During the 3 to 4 minute test at 70V and 5A under no load, I was surprised to see the motor was quite hot, pushing 80 degrees C. I guess all of that 350W is going into heat... The controller did not get much above ambient during the test. The strange thing is that my rewound 80-100 does not get nearly that hot, even while under load on my bike. I think 50 degrees C is the most I got on that one under average power of 1000W for 10 minutes. It has internal halls placed at 120 degrees and was powered by the Kelly. Might the excess current draw and subsequent heat generation have something to do with the externals halls not being perfectly placed and hence providing poor timing? Anyone else seeing 5A no load current @ 70V for the 130kV motor?
over
[youtube]OL4XvbuKoYk[/youtube]
over
