Folks,
This is a question for Luke, and the other motor experts on this site. Running a motor through a gear reduction, means I can use a lower wind/higher rpm motor at the same battery voltage, just geared down more, for the same power/speed. This should allow lower motor current for the same output wattage, and greater electrical efficiency...correct?
I have had a new bike project present itself. My wife, after riding thousands of miles with me since 1995, and after several arthroscopic knee surgeries, and one knee replacement, now facing the other knee ultimately needing replacement, is giving up cycling. This leaves me with our RANS, dual 26" wheel, Screamer tandem. Here is a shot of me and our daughter from 16 years ago.
http://www.rowvelo.com/images/26-26Scr.jpg
I am thinking of pulling off the stoker seat, and chopping the crank arms off the stoker crankset. I would mount a 6T, "500 watt" MAC, from cell_man, Paul, in the frame, just below where my daughter's hands are, in the picture. I'd use his "1000 watt" controller. I would mount 12, 100Ah GBS cells, from Elite, 6 per side, down low on the frame back there. I'd run our "rough road" 2" slicks, instead of our usually 1.25" slicks. This rig would come in at about 145 pounds. I figure, since I have the extra bottom bracket back there, I will take advantage of it. That extra shaft allows me to up the motor rpms, without having to use custom chainrings to keep my cadence normal. I would go with the 100 Ah cells, because they match the weight/Ah of my big Ping pack. I figure if I run this bigger motor at 2.5 times the 350 watts, I run my current bike, or 875 watts, I should be able to cruise at 28 mph average, instead of my current 20 mph average. And with 3.3 times the energy available, and only 30% higher gross weight my range should be as good.
Warren, at 3000 miles on my bike
