Thibaudcnlc
10 µW
- Joined
- Sep 17, 2022
- Messages
- 5
Hi everyone, i've recently bought a go-kart. From what i've found it comes from a kart renting circuit and the kart is made by a company called Speed2Max.
The problem is that it commes with a asynchronous motor and a mysterious controler. I cant find any informations on this controller witch is sad because a 350A 48v asynchonous A/B ESC is not common and expensive. I've tried to connect the system to a 48v power supply but it does nothing. The capacitors in the controller are charging like any other controller but no sign of life.
The controller is coupled with a proprietary board from speed2max so i thing this is whats causing problem but without a datasheet of the controller i can't bypass this board.
The picture of the sticker is the only information on the controller and the pic of the pcb is the inside of the controller. If anyone have an idea it would help a lot.
Thanks.
Thanks.
