BiGH
Hey Endless-spheroids,
Just wondering if it is possible to keep packs of different amp hours of capacity connected (and reilable) in either series or parallel. I currently have 2x 36v 12ah packs. I've got another pack on order.
I was thikning about this - what would happen if my other pack was a 20ah pack?
Could i wire the two 12ah packs in SERIES for 72v, and have the 20ah wired in series for 72v - then parallel both off the controller?
would this mean that if the BMS tripped on one it would see the full pack voltage of the other? (ie fried components?)
The reason i'm thinknig of doing this is so that i can reduce the discharge rate of the pack.
It would be easier to run two sets of packs of the same amphourage, however if one tripped before the other i'd be worreid.
ie should it be 2s2p or 2p2s? and mismatched?
