Votol EM-100 Configuraion
Green4Life
Pakistan
Hi All,
Is there any parameter in the votol em-100 or em200 controller that can be set to a specific value so that it will not drive the motor?
Regards,
Might need some translation on this, what are you trying to do?
Hi, Thanks for your comment
Basically, I want to know if there is a parameter that can be changed so that the controller will not drive motor, and as a result the vehicle cannot be driven any more.
I think the speed limit setting can be used to limit the speed to 0, not sure what the speed ratio means here.
If you just want to permanently disable it, why not disconnect the battery, or motor, etc., from each other?
If you're not looking for a permanent disable, then you'll need to specify exactly what you are trying to do under what specific circumstances.
