MaartenZonneveld
- Joined
- Jun 4, 2020
- Messages
- 3
Hi, I am new on this forum and was not able to read all the Votol controller related items (did a scan though but could not find related item).
I have a problem when connecting my Votol EM150-SP (with CAN) to my battery of 72V (also when QS-motor is not connected). It looks like a too large current is drawn from the battery and as a consequence the BMS of the Battery (self build 20S battery with 40A BMS) goes into discharge protection and switches off the power. I contacted QS motors for advice and they only could advise me to read out the controller software settings to check if that is correct. Unfortunately the connection with the controller can only be established when controller is connected to 72V supply (which is not working due to the described problem... ).
Potential problems I can think of:
- Problem is caused by battery/BMS (is 40A version large enough or should I have used larger one (60A)?
- Problem is caused by controller (short circuit, controller settings)?
Both potential problems can be solved by ordering new stuff of course, but I am wondering of any of you have experienced the same or have an idea how to solve ??
Thanks in advance for your help!!
