Hello again! I recently purchased the Hobbyking 100a ESC (http://www.hobbyking.com/hobbyking/...C_US_Warehouse_.html?strSearch=hobbyking 100a along with a wiiceiver and kama nunchuck (from ebay). I have this weird problem when I plug in the esc to the battery (connected with a ntm 50/60 motor) I have to press the controller stick down in order to first arm the motor. Then if I release the stick it will immediately accelerate in the neutral position. I tried reflashing the ESC with just about every setting I could think of. I have calibrated the wiiceiver and kama controller multiple times. I don't think it is the wiiceiver though because I can see the LED light up green when I push the stick forward and then red (brake) if i push the stick down. Can anyone have any suggestions to where I can have the motor completely off when the stick is neutral and then accelerates when i press forward/brake when it goes backward?
I also have bought this programmer ( http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=35668 ) Do i need something different?
