kdog said:Hey willow, RTL
Sunday morn is probly my best bet for a ride- I'll run it past the boss.
What happened to the DN? Did I read you're getting another
Kdog
silviasol said:Sorry for this stupid question but I am about to hook up my 230v welder but need to rewire it to hook up to my 230 power plug. Is there any difference in which wire goes to where or is fine to have either side plug in like 120v outlets?
TotalConfusion said:silviasol said:Sorry for this stupid question but I am about to hook up my 230v welder but need to rewire it to hook up to my 230 power plug. Is there any difference in which wire goes to where or is fine to have either side plug in like 120v outlets?
Yes there is a difference, DO NOT just pick a side and wire it up, If memory serves me right as i have been out of the business for 5 yrs now but the left hand side is the positive on the GPO on the wall.
So when you look at the plug front on, its the prong on the right hand side. Your plug should be marked on the inside next too the screw terminal.
izeman said:if you think about it: there is no way to know how the wall outlet has been wired.
it should not hurt because the the voltmeter has extremely high ohm, but it would if the meter is set wrong as ex to measure current :lol:Punx0r said:I'm not an electrician, but using yourself as a ground for 220V doesn't seem like a good idea?
Yeah, if the multimeter is set to measure current it will wake you up in no timemadin88 said:it should not hurt because the the voltmeter has extremely high ohm, but it would if the meter is set wrong as ex to measure current :lol:
Punx0r said:Anyway, don't you folks have different wire colours for live and neutral?
