You may wish to inquire how old are they, and how hard have they been used, under what conditions? The older they are (even unused) and the harder they have been used, under harder conditions, the less capable they will be in any subsequent application. You can overcome this by paralleling more cells, but the battery gets larger and heavier.
Keep in mind a (summarized) phrase from Dogman: "a used battery is worth nothing / $0 until proven otherwise".
If they are for the bike referred to in the thread linked by A-DamW, you might need a lot of cells to do the job you need.
If you haven't already done so, you should define that job, so that you can then determine the capacity you need to get the range required, and the current capability to get the power you need, and the voltage required to get the speed you need (vs the wheel size and gearing vs motor RPM).
