ou lose about 15% startup torque at most from hall sensors when set up correctly due to the 30 degree angle ambiguity. You shouldn't need separate algorithm for this. There isn't a better algorithm than FOC with mtpa using current control and the best known angle, which with hall sensors at zero rpm is the mid angle of that sensor.
Does that mean a sensor less controller is better as no hall sensors ?. I had a 1,000W hub and burned out the sensors and ran it about 2 years until it died with a Greentime sensor less controller. It seemed to have more power but could be the stock controller was 30 amps. The sensor less was 35 amps.
My experience with hub motors is the first hub kits snapped the dropouts especially cast front forks. That is start up torque from my experience. It is too much torque at take off., What caught my eye when I saw this post. The newer hub kits are much better with power assist levels that work like gears.
Even with that I prefer a rear hub motor vs. a front. However if a front hub is used there will be a much greater chance of NOT snapping the front drop out if it is a dual hub motor set up with a rear hub exactly like the front and identical controllers hooked to a single throttle controlling both motors.
With the rear pushing at the same time the stress on the front fork is greatly reduced. Also dual hub motors run cooler as greater heat dissipation. It will greatly increase the life of both motors and controllers vs. a SOLO motor doing all the work. Then there is greater traction and better handling off-road.
My guess is 80 to 90% of the stress on any DC motor happens during start up / take off. With a power meter measuring voltage , current and peak power the start up is the greatest stress on the moving internal parts of a DC motor. Power peaks then and levels off as speed increases. There is half that stress iwith dual motors.
Only draw back is turning at high speed. You need to slow down and let off the throttle when turning. If the front hub is engaged turning will be a lot more difficult. I learned that the hard way. OUUUNCH ? Me and my e bike got a little banged up.. It was crazy.
Instead of a brake sensor someone needs to invent a sensor that shuts down the front hub when the wheel turns at a certain angle. That would reduce the calamities due to human error. Until I invent that just be aware. Dual motors are great. Just slow down when turning. It could save your butt.
I am not supposed to give any advice so only quoting another source from here on ES regarding handling with a front hub.
Thanks.
Skyler.
