bmwupgrade
100 µW
- Joined
- Jun 13, 2021
- Messages
- 9
I made one fundamental error due to late night writing I accounted that reducing turns will reduce KV when it is an opposite. Sorry math is wrong Star is better in temp and torque per amp.I'm not sure I follow your logic but I think you need more turns in delta to get same kv, not less(if everything else in motor stays same)
Edit: And when you adjust winding turns in motor to get same kv, you would also get same kt.
So 7 turns in star vs. 7*1.73=12 turns in delta.
63/12=~5strands if you then calculate resistance for both windings they would be same
Though there are reports that triangle is running a lot more efficient at High range of RPM, but I have no idea why that would be + considering the difference in amp draw to get to approximate torque level (1.73) + increase in resistance that you have to to do by adding turns to get same KV motor = same torque, it all seems to be too much to be beneficially if you don't have an objective to get higher RPM.. (but than again, for that you could as well just get star winding and reduce the number of turns but 1.73 times - which would also allow for more parallels further reducing heat up or allow for higher torque
