nechaus said:Thats right! you have a thing o matic,
The Replicator 2 looks really amazing, its looking closer to a resin printer res, But the price is crazy, you could buy 3 reprappers for that price.
but you could get a resin printer for that price ... soon they will be in the $3000 mark
I'd love to, but:nechaus said:Im still not sure what path im going to take, I do love my printer, its awesome for brackets, But still want a second printer, Not sure if i should get another 3d stuffmaker printer, or get a replicator or wait for a cheap resin printer to come onto the market that will do extreme res prints
Do you have any cool things to print on file that you can send ?
When I bought the bot like 30 months go the only option was to build from a kit. Being careful is no substitute for being experienced. I've had lots of failures, and long periods of down time between pockets of up time. I've probably done only about 200 builds.nechaus said:How many prints have you done so far?
I think id be getting close to the 200- 300 mark lots of failed prints, and also just chucked some bits that i printed.
Gonna try that especially since my latest problem is loss of power to the heated build platform. No heat == no stick to kapton.nechaus said:I enjoy printing on blue painters tape more than a cold bed with kepton, it really sticks well, sometimes to well and have to use acetone to get the tape off.
Just ABS, but I have 5kg of PLA just sitting there.nechaus said:Have you tried printing with PLA or just ABS?
ReplicatorG, something like #29, the newer versions leave the T-O-M behind IIRCnechaus said:What software do you use?
Slow. That's not sarcasm. I'm in RI a few days and the T-O-M is in Massachusetts, so I can't get you numbers just now. But what are numbers anyway. The damn thing is slow.nechaus said:What speed does your machine work at?
Maybe, maybe not. These original MakerBots were all laser cut plywood - and by plywood, think pine/balsa not oak/walnut or whatever.nechaus said:looks alot stronger than my plastic frame !!!
Done already. I'll have to take decent pictures, but think of its original design as a cube - all six sides having a panel. All panels bolted together, making a rigid box. Now notice it's taller (Z-axis) than it is wide in the X and Y directions. So, to stiffen it, there's a platform (an extra stiffening member, a shelf) inside, right behind where the red letters say "MakerBot" in the picture. Rigidity is important for good prints.nechaus said:So are you going to put some aluminium on the frame to strengthen it ?
I've done a couple of FW updated - PITA. I've stopped upgrading FW for now because the last time I did it, it made things worse not better and I had to revert back. I'm going to be very careful with future changes. MakerBot's latest machine is 2 generations newer, that's where their focus is...nechaus said:Have you tired updating the firmware for it? I was shocked at the difference it has made on mine with new software..
MattyCiii said:Maybe, maybe not. These original MakerBots were all laser cut plywood - and by plywood, think pine/balsa not oak/walnut or whatever.nechaus said:looks alot stronger than my plastic frame !!!
Well, I took the bottom panel off. All the circuit cards, and the ATX power supply, are all in those bottom 4-5 inches of the 'bot. A clean, enclosed, compact design, as long as wires don't fail from flex or other things don't go wrong. I took that bottom off - that's what you see to the left of the machine. But that means there's a whole panel missing, and the machine is much less stiff. So, I bolted that aluminum picture frame to the inside very bottom of the device. It's now stiffer than it ever was before.
My latest print crapped out at about 8mm height (out of 30). I've adjusted the build parameters, and am going to try one more time tonight.
I'm thinking poor adhesion. Looking around, there's a recommendation that he extruder should be ~5 degrees C hotter for black ABS than for natural. I've recently started printing in black...nechaus said:Why did it crap out @ 8 mm height ?
0.4mm so far, nothing else.nechaus said:What nozzles have you tired?
Kin said:My printer comes in tomorrow...I have a busy next 10 days though, I might not get much time on it. *major alas.*
Will post pics soon. My first order of action, after I do a few thingiverse Stls and so forth to get the hand, will be a case for charging up individual 18650s with a few terminals I bought from newark using the 6s hyena isolated charger.
