Hi All, I searched the forums a bit with no luck,, We were gifted an older low miles X-Treme XB-300Li 24V,, I got it running with a couple of 12V SLA batts in series, strapped to the rack.
It looks like the original batt is a bit hard to find,, This is the case - https://www.aliexpress.us/item/2251801374693247.html?gatewayAdapt=glo2usa4itemAdapt
I bought one of the X-GO Silverfish 24v 10ah batts and it is a bit too big to fit in the seat post location. The old one is about an inch smaller,,
Has anyone found a batt that will fit?
Does anyone rebuild the old batts with new cells?
Was probably just going to cut the frame cross piece and weld a bit and make the new 10ah batt fit. This way its easier to get a batt in the future. Has any been through this and what was your solution?
Thank you
Thank you
