Hi
I am new here, and was wondering if anyone has had any experience with this bike or any thoughts.
Is 300 watts big enough to get 20mph? I am around 230 pounds
I think I like the idea of full electric or switch to pedal assist, I have pretty bad back problems but would like to pedal until the back hurts to much then switch to electric power.
Any thoughts on the battery system it has?
Any questions I should ask them that are missing in the info below?
Power: Electric
Watts: 300 Watt
Motor Type: Brushless Hub Motor - Motor is in center of rear wheel
Gears & Speed's: 7 Speed Shimano Tourney® Gears & Shifter
Amps: 56 AMP Circuit (7 Batteries at 8 AMP's each)
Volts: 24 Volts (Each Battery Is 3.6 Volts)
Batteries: 7 - Lightweight Lithium Batteries In A Sealed Removable Pack
Tire Size: 26" x 1.95" on Aluminum Wheels
Charger: Smart Charger Included
Tool Kit: Included
Speed: 20 MPH
Distance: Up to 20 - 25 miles per charge - can still pedal if charge is lost
Throttle Type: Variable Speed Control - Twist Throttle - or - Pedal & Power assisted
Key Start: Yes
Frame Type/Size: 100% Aluminum - Very Light Weight / 18"
Forks: RST Capa® T7 Front Hydraulic Forks Made (Top Name Brand)
Braking System: Front and Rear Brakes
Drive System: Rear Hub Motor (Motor is in rear rim) + Pedal Power
Head Light Yes
Measurements: Wheel to Wheel 72" - Width 25" - To Bars 37"
Adjustable Seat Height 37 3/4" to 45 3/4"
Carton Size (LxWxH): 58 x 11 x 30 inches
Shipping Weight: 63 Lbs
Bicycle Weight: 52 Lbs (Including the light weight battery pack)
Maximum Rider Weight: 350 Lbs
Horn/Bell Included: Yes
Battery Indicator: Yes
Cargo Rack: Included
Warranty: 90 Day X-Treme Warranty - 1 Year Battery Warranty
Power: Electric
Watts: 300 Watt
Tool Kit: Included
Speed: 20 MPH
Key Start: Yes
Head Light Yes
