Hyena
I <3 Methods
(only if it sees the light of day )
mwkeefer said:Methods,
Nice GUI - did you write that up?
El_Steak said:I bought one of their ultracheap 50 watts Accucel-6 charger (20$!!!)
I know its slow, but from what I read its reliable and precise enough. Anybody tried it around here ?
Hyena said:Leave room for integrating GPS signals oh supreme programmer
Package your hardware with one of those cheap $100 chinese WinCE powered touchscreen 5 or 7" GPS's
like this
oow, my pants just got a little tighter
GCinDC said:I finally bought a mean well SP-320-48, ... I could set it to 20.5V and hook it up to my parallel harness...
Hyena said:Yep, check out THIS THREAD
I've posted alot about modifying them for lipo charger use and also about extending their rated voltage range....
The cool thing about such a small simple pack is it wouldn't be hard to charge each 22 volt pack at a time. This would be my spare pack for long rides or when I want less weight offroad so charging in a hurry isn't a priority.El_Steak said:Its also deceivingly simple to mess up. Especially switching between series for discharge and parallel for charge.
Seems like the most common mistake is connecting the main leads in series while the balance taps are still in parallel. For that reason many are moving to full-pack charging solutions with power supplies instead of the 6s-10s RC chargers. Of course, this leads to other challenges such as the need for a BMS system.
Search the forum for "KFF" (Kentucky Fried Fingers) and you'll find plenty of examples of what happens when you make a mistake.
Best (worst?) example I`ve seen in this thread is this: http://endless-sphere.com/forums/viewtopic.php?f=14&t=9170
I would recommend spending a few hours reading this thread and the "Lipo Care..." thread ( http://endless-sphere.com/forums/viewtopic.php?f=14&t=10817&p=235386&hilit=kff#p235385 )
Lipo is like the resident hot chick in a bar. She's hot and easy and you want some action with her, but if you're not careful you might end up with some long term ill effect on your appendage.
