AndyH
Ypedal said:- If i leave the BMS plugged in with the ballance leads and the + and - leads hooked up to the pack, cell no.24 gets drained significantly ( like 1 ah over 48 hrs )
- If i leave the ballance leads plugged in but not the + and - everything is ok.
Looks like you have a damaged channel, Gaston.
Ypedal said:Something strange i've observed is that chanel 24 will start to flicker faintly when the pack is just starting to ballance but cell 24 is still at the 3.4xx volts, the other chanels only start to flicker when cells get to 3.6xx volts
Yup...definately a bad channel. The TC54 low voltage detector is wired directly across the cell. If reversed or overvolted, it'll fail as a short...until voltage is increased to about 15V and the little puppy explodes. Then it's not a short any longer.
Inject voltage into channel 24 the same way you connect a cell - positive into the pack positive and negative into the far 'right' shunt resistor lead. You should be able to turn the voltage down to active the LVC signal and up to activate the shunt.
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=13380&start=15#p217405 Pictures!
Andy
