I am starting to build my first battery for a hub motor 9c in a Trek 700c commuter.
Here is the start of the pattern:
Here is transferring the pattern to a piece of flat material (easier to take notes on, and more true. The wooden pieces sometimes flex)
Now we put the flat pattern in the triangle, and... it doesn't fit. I had to sand off a bit to get it to go in there. The wooden pieces did indeed flex around some obstacles, like the bosses for the water bottle cages.
Now it fits!
The idea here is to use Leamcorp's battery box tech to fit a small 36v 10ah A123 pack in there. This is actual size:
And this is how it will fit in the space:
That's as far as I've gotten so far, I'm deep into testing the cells that I need, hope to start cutting bits of wood soon.
Oh, the attachment points are going to be Riv-Nuts that I got from a local fastener place. They're only aluminum, but hopefully that will be enough.
Wish me luck!
Katou
Now it fits!
Wish me luck!
Katou
