Offroader said:
I wanted to add that it was obvious I didn't use enough tension on my other builds because the spokes were unloosening. Would more tension have stopped the spokes breaking on hard hits I don't know for sure. I thought I had those spokes reasonably tight.
So I am not going to say at this point that 9/10 gauge are better than 11/12 gauge or even 12 gauge when I didn't have my wheel tensioned properly.
Will I personally use smaller spokes again? absolutely not.
It's kind of hard to imagine what is going on with a spoke while in a wheel. I kind of think of it like a guitar string or a trampoline spring. For these things to work, they have to be under the right amount of tension and stay that way, just like a spoke.
Another thing to consider are the purpose things were made for. I wouldn't use guitar strings on a trampoline or trampoline springs on a guitar. Just like I probably wouldn't use triple butted 13/15/14ga spokes on a hill jumping dirtbike nor would I use the tree trunks you call spokes on a electric bicycle. If you were going to make an electrified
bicycle, especially in the case for transportation as many do on this forum, the common opinion around here of using thinner spokes would probably be a safe bet.
I couldn't tell you if you had enough tension on your previous wheels, but the only difference which makes no difference is no difference.
If I was making a wheel where a lot of jumping was involved, I'd probably not use a hub motor, I'd probably use a chain drive of some sort. You might consider looking into the idea of using some really light loctite (also called thread locker) in this wheel build, loctite 222 is something I've seen recommended on forums and in wheel building books for spokes. I am no wheel building expert, but I imagine downhill biking, dirtbikes or very fast ebikes are all great candidates for some sort of thread locker.
Personally, I don't really get the appeal of massive hub motors. For a while I thought that they were more efficient and that the higher thermal capacity was always better. These massive hub motors have huge rotational weights, and don't make great wheel hubs. Using a separate motor with a chain drive isn't just going to be cheaper, it opens up so many options. There is plenty opinion around about really massive thermal capacity and ways to improve these capacities (oil, vents). You might just be able to find a water cooled electric motor, and pair it up with big radiator for some insane thermal capacities. Maybe make the cromotor mammoth look like a wind up toy.
I couldn't tell you for certain how the spoke head touching the hub is going to interact, I guess in your case, time will tell. Maybe the spoke head will just gouge into the hub, maybe the spoke elbow will break, maybe the head will pop off like a dandelion, or maybe a thousand beautiful people will dry hump your wonderful dirtbike to celebrate it's glory, who knows. I am hoping there will be humping though.
