dumbass
Hence a problem with commercially available BMS then isn't it.......
Bob
Bob
dumbass said:Hence a problem with commercially available BMS then isn't it.......
Bob
Tommy L said:dumbass said:Hence a problem with commercially available BMS then isn't it.......
Bob
I've done 850watt load tests on Headway 8ah Red cells in a 4S2p 16ah (4.5C discharge)
You can see that the last 2 minutes (11 and 12 minutes) it's dropping fast!
If you did the discharge to only 80% you would stop at the 10 minute mark at 3.00v per cell
Tommy L sends....
http://elektromotus.lt/en/products/bmsdnmun said:i know of no commercially available BMS that have adjustable HVC or LVC. i have analyzed about 8 different BMSs and none of them use 2.8V as the LVC. every one uses 2.1V for the LVC.
dumbass said:Tommy....Thanks for the data. Based on your testing I feel comfortable with my 2.7v LV alarm setting. Not to mention that I do not consider TS or GBS cells to be in the same class as Headway Red cells. As I've memtioned I only use an alarm not a cutoff. So I can turn off the alarm and continue riding if I feel lucky.
Bob
dumbass said:Hey Tommy,
This is a hard question for me to answer because I've never had any HeadWay cells of any kind. I have 2 each ThunderSky and GBS.. 24v 20ah packs. I run them as ether 24v 20ah packs or jump 2 together for a 48v 20ah. I've been running the TS for 3+ years and have never had a cell problem. I've had the GBS packs for about 18 months but they have never been mounted on a bike. I bought them for my wife's bike for when her lead died. But it never did and she's happy with the lead. So I am going to use them on a new build this winter.
I buy the GBS cells as a 4 pack for $124 for the 4 (12v 20ah). They are prismatic cells with connection studs same as HW cells. They are oly rated at 3c. With my TS cells I draw less then 2c with them. One of the things I don't like about TS or GBS cells is they are rated at 2.8v to 3.6v. I charge to 3.65 and have my alarm set for 2.7v.
Just based on all the cell ratings I would say HeadWay cell are a better cell. In fact I have considered putting together a 48v 20ah Headwa pack or maybe use the 15ah cells to build a 48v 30ah pack. But I already have the GBS cells so I don't think it will happen.
Bob
dnmun said:but you miss the purpose for having LVC. it is not there to allow you to run the pack to exhaustion, it is there to prevent the accidental over discharge of the pack which happens when the pack is left attached to the motor with the controller on and people go off and leave it unattended. that is what the LVC is for, to protect the pack from the owner.
the HVC is there to prevent over charging as the cells age or get damaged from overdischarging, and go outa balance.
like i said at the beginning the thread is for those who don't understand how a BMS works and instead just wanna call it a 'battery murdering system' because they think it is cute to say.
a BMS does not prevent you from using the pack within a narrow operating envelope, it just protects the pack from mistakes and accidentally leaving it connected to the load and also from overcharging.
dumbass said:Rest assured that just because some of us choose not to use a BMS is not an indication we do not understand how it work or it's purpose. It's simply our choice.
Bob
dumbass said:dnmun said:but you miss the purpose for having LVC. it is not there to allow you to run the pack to exhaustion, it is there to prevent the accidental over discharge of the pack which happens when the pack is left attached to the motor with the controller on and people go off and leave it unattended. that is what the LVC is for, to protect the pack from the owner.
I agree a BMS has values and your example of leaving the controller attached is one of them. However, I don't remember anyone saying or even implying a BMS was a "battery killer". The comments of some are simply pointing out that there are alteritives and they ( I ) are sharing some of these alteritives. You keep insisting that many commentators don't understand a BMS just because we choose not to use one. Rest assured that just because some of us choose not to use a BMS is not an indication we do not understand how it work or it's purpose. It's simply our choice.
Bob
dnmun said:LVC is a value set by the BMS. it has nothing to do with the manufacturer. any and all lifepo4 operate in a voltage range between 2.1-3.65V.
lipo is different. it will be damaged if the cell voltage drops below 2.7V.
etriker said:dnmun said:LVC is a value set by the BMS. it has nothing to do with the manufacturer. any and all lifepo4 operate in a voltage range between 2.1-3.65V.
It depends on the make.
The best way to know is to find a data sheet for your cells.
Notice where the A123 cells fall off the cliff.
http://www.batteryspace.com/prod-specs/6610.pdf
They are done at about 2.5v ?
I use these for my A123 packs for lvc alarm.
They are easy to hear. Loud.
http://www.hobbyking.com/hobbyking/store/__18588__Hobbyking_2_8S_Cell_Checker_with_Low_Voltage_Alarm.html
It is easy to set the alarm voltage to 2.7v.
For charging hvc I use this hooked to an old dell.
http://www.hyperion-world.com/products/product/HP-EOS1420iNET3/
It gives a lot of feedback on the condition of the cells when charging, charges fast and gets the cells in balance.
I also use a watt's up meter like a fuel gauge on the car.
http://www.amazon.com/Watts-Meter-Analyzer-WU100-Version/dp/B001B6N2WK/ref=sr_1_1?ie=UTF8&qid=1345815721&sr=8-1&keywords=watt%27s+up+meter
I don't want a bms that can cut the bike off in the middle of a big intersection with a pickup truck 4 feet right behind me.
I would rather have a loud beeper go off and then I decide what to do next. Time to pedal.
Tommy L said:My view on the "BMS Free" is to understand Batteries and or Cells. Watch them under different conditions of use. I enjoy to know my stuff.
Others out there could care less, plug it in, drive it. There are many car drivers out there that know the car has a "GO" pedal and a "Stop" pedal and where
to put fuel and follow GPS directions down a narrow alley. Just saying! lol
Tommy L sends....
