speedmd
I think the link has it backwards on the effects at least going by what I have read / experienced in the past. Wiki has some on the topic that may shed some . http://en.wikipedia.org/wiki/Bicycle_and_motorcycle_geometry
Source of quote:“Head angle,” “caster angle” and “rake angle” are all the same measurement.
Source of quote:
http://motocrossactionmag.com/home-page ... o-about-it
speedmd said:Clearly a wrong statement. Typical of a mag writer. All are very different, and it is not just nomenclature.
this document is a simple trail calculator for bicycle's..& the math will gel for differing wheel diameters....I can find many examples of it used as "offset" or "rake"From the bike cad site the above picture is from In the motorcycle industry, caster angle is synonymous with what would be called the head angle in the bicycle industry. Sometimes in the bicycle industry, the term caster angle is used to describe the arctangent of the trail divided by the wheel radius. To avoid confusion, BikeCAD does not use the term caster angle. However, for those that are interested in this value, BikeCAD does display a dimension called the arctan(trail/wheel radius), (known by some as caster angle). This dimension is shown above.
Offset is used primarily to determine the correct amount of trail for a given head angle. Motocross front ends typically use between 18mm and 25mm of trail.
Including this passage? "To avoid confusion, BikeCAD does not use the term caster angle. However, for those that are interested in this value, BikeCAD does display a dimension called the arctan(trail/wheel radius), (known by some as caster angle). This dimension is shown above."speedmd said:Yes Thud I have read them all..
speedmd said:It is Easy to understand trail numbers. Unfortunately, the trail targets vary depending on wheel size. What you do for trail on a small wheel scooter is very different than a fat bike even when your looking at designing in the same steering characteristics. Rake - offset give various degrees of shock transmission, front end flex and feel and many times are not just for hitting trail numbers. Within one product group, I agree, much is used interchangeably and will work, but the math when taken to its basic/simplest form, IMO, it would be the caster angle as shown in the bike cad drawing as the most direct indicator of how the front ends steering will act.
