Ch00paKabrA
Punx0r said:Like the Marzocchi 888? I've seen a couple of sets of those for sale.
Do the regular suspension forks I've seen with adjustable travel achieve a variable crown-to-axle length?
I'll bear the spacers in mind. You've also reminded me of the Crane Creek offset headsets, but they ain't cheap.
I don't know what type of bike you have but I don't think that the Angleset headsets from canecreek will fit in a regular 1 1/8 head tube. I have one on my Gary fisher Kingfisher but that has a 1.5" head tube and I have to use a 1 1/8 steerer tube fork on it. Also the angle change is relative to the length of the head tube so even if you get the 1.5 degree angle set, if you have a really long head tube, it may only slacken (or steepen) the head tube angle one degree.
also the 888s use a 20mm through axle. Do you have a 20mm front hub? If not, then you have to buy a new (or used) front wheel which will set you back dinero.
