DrkAngel
1 GW
Homemade Battery PacksNehmo said:I now have the bike, but I didn't get the Currie SLA battery. I used 2 U1(lawnmower) 12Vs in series. It's heavy at 105 pounds. Where did you, DrkAngel, get the cheap Li batteries?
`~- Nehmo
`~- Nehmo
Solcar said:DrkAngel said:True ... The 2008 model was noticeably noisy.vanilla ice said:I think you can use "SPORTS20" to get $55 off too. You have to use an Amazon credit card though. Coupon should be valid until June 15th.
Noisy motor, but if you don't mind the noise its pretty good otherwise.
By comparison, the 2009 model was, nearly silent!
Hopefully, the newer models, improved, even more. ... ?
I am guessing that this is a clearance price, on the 2010 model.
I've read that adding a plastic spacer inside the gearbox can quiet it down a lot.
Volts is pressure, higher pressure = more power.icecube57 said:2-10 times their watt rating. Meaning a legal 750w kit Double that is 1500w. 10 times that is 7500w. In no way did he say anything about 100+ volts or 72-360 volts
Which would make them red hot!icecube57 said:But from a stand still the motor will draw whatever the motor wants as long as the controller current limit isnt hit. In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
Actually ... in a "lock test", Increase of amps increases wattage input ... motor wattage output is zero! Heat does not count.icecube57 said:So the increase in amp does increase wattage output up to the limitation of the winding in extreme cases.
DrkAngel said:The only way to increase watt output on a hub motor is to increase the volt input!
Unless you rewind it?
Volts x Amps = Watts
You can't force in more amps unless you up the volts..
Hillhater said:Errr ? .. have you never heard of the controller limiting the amps ???
a simple change of controller can double the power output from some stock Ebikes.
Not entirely true. Most controllers limit the current available to the motor. So, if you upgrade or alter your controller to allow the motor to take as many amps as it demands, then (and only then) is your statement true.DrkAngel said:...
You can't force in more amps unless you up the volts...
Beating a dead horse my friend.icecube57 said:I can post the results for a 5303 that will clearly show an upgrade in amps clearly increases output power...
I would think it more cost effective, reasonable, to over volt -amp, the more "world standard", 250w motor, than to down regulate a 1000w, or higher, capacity motor?Hillhater said:Remember DA, we are talking of commercially sold Ebikes ...which have to meet the legal limits, so it is common for manufacturers to install a controller that limits the output to suit the requirements.
Change or modify the controller and suddenly you have more amps available at the motor for either performance.. (or smoke if there is a weak motor also :wink: )
Have a link to better pictures of "Motor Simulations"?icecube57 said:Output profile of a 30A controller and a 100A controller.
DrkAngel said:Which would make them red hot! They add a fuse to prevent motor burn up.icecube57 said:In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
Search the windings! Most all, should have thermal fuses, look for the odd piece, or pieces, of small tape.neptronix said:DrkAngel said:Which would make them red hot! They add a fuse to prevent motor burn up?icecube57 said:In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
Do you mean to say that there are fuses in 3 phase hub motors?
I haven't found any in any of the motors i've pulled apart, where are those fuses DrkAngel?
