madm3chanic
you just gotta be careful with the width around the bottom bracket area. any wider than about 120mm too close to the bottom bracket and the sprocket or the cranks will hit it (even with a 100mm BB shell the space between the insides of the cranks is nowhere near 150mm) which is why you can see on the raptor the battery cavity doesnt get that close to the bottom bracket. my only concern there is that its gonna raise the COG a fair bit by not allowing any cells to go down near the bottom bracket.
done a fer renders of the front triangle as per that sketch i did-
havnt really worked out any nittygritty like how to join the tubes around the bottom bracket area, just trying to get a feel for the aesthetics and configuration like this.
personally i really like the distinct transition from the frame to the battery box; i think thats the main reason i like this design aesthetically over the first design i did. with the distinct separation between the box and the frame, it kind of makes it look less bulky than on the other one with the battery cavity as part of the main structure.
PS doen anyone know why sometimes the forum displays pictures inline, and sometimes just does them as a download link like above?
