Oh, I think the 3220
definitely has more than enough power for a 26" bike. Earlier, I got the bike back together, and went for a 3 mile test ride. Wow, what a difference not having the bike chain move, makes on performance.
It runs smooth as silk now, and it seems to have much quicker acceleration. I got the front wheel to pop up, shifting from 2nd to 3rd. I tried goosing it in first, from a very slow "crawl", but I couldn't actually open it up all the way because it almost flipped me off the back. Frankly, this is a bit too much for me.
Today I hit 116A and 5500W peaks, and after 15 minutes, or so, of tearing around our neighborhood, nothing got hot at all. The controller was 96F and the motor was 108F.
I also did a couple of speed runs, to see how close my spreadsheet predictions were, and near as I can tell, they are spot-on. 1st gear topped out at 20 mph, 2nd got up to 28 and I stopped at 35 mph in 3rd, as it was just to scary to go any faster. The spreadsheet says it should top out at 37 mph in 3rd, so I was close. Using a 26" wheel, the spreadsheet says the top speeds should be 27 mph, 36 mph and 48 mph, in 1st, 2nd and 3rd, respectively, assuming you use a 3-speed hub. This is also assuming you use the same 11t/94t gearing, and a 7-turn 3220, which has a kV of 97. I think on a 26" bike, this setup is much more suitable. I just can't see using 1st gear on this bike, going up any hill, as I'd be too afraid I'd end up on my butt.
I'll tell you the setup I'm dying to try, and that is this similar direct-drive configuration, but on a singlespeed beach cruiser. Instead of the 3-speed hub, however, I'd do delta-wye switching. I've got some 60A latching relays coming, that I will use with a circuit Richard did that will ensure these six SPST relays all switch properly, and quickly. Looking at the numbers, I think I'd probably use an 8-turn 3220, which has a kV in its normal "wye" mode of 84. In delta configuration, the kV goes up to 145. In wye mode, the top speed would be about 30 mph, and in delta it is about 53 mph. Actually, 50 is probably the max, as the wind drag really comes into play once you get above about 45. Anyway, this would be a great all-around setup, with gobs of low-end torque, and a top speed that would let any commuter keep up with traffic.
I took some more pics before it got dark, but they are still in my phone. I'll post them in a bit. Next up, I want to redo the setup in my other folding bike, which currently has a 3210 10-turn (kV: 113...) and a Nexus-3 hub, with an "extra" reduction stage. It has a #25 chain 1st stage reduction with 80t/24t and a regular bike chain 2nd stage reduction to the hub with 34t/12t. That's a total reduction of 9.4:1, which I can match with the direct drive using the same 94t big sprocket and a 10t motor sprocket.
-- Gary
