gwhy!1
macribs said:Gwhy, are you saying one could run both controllers for one motor? To have the advantages from both controllers?
So at low RPM I use them hall sensors and a regular controller - that take care of all stand still launch issues and let you launch by throttle from dead stop.
Then as speed and RPM rises the "launch" controller falls back and the RC esc takes of and now run the motor without any care for the hall sensors.
This would actually solve many problems. It would be easier to use gyro sensors to control acceleration and avoid wheeling. The sensored controller would work far from it's limits because it would not be used to push max current etc as it only needs to work trough part of the motors band width. It might even let you use a lower cost or smaller foot print controller as the rc esc takes over anyway. That could meanie you might get away with the adaptto mini rather then the double sized and double prized maxi. So now you can use the smaller and cheaper of the two adaptto's.
I think the Achilles heel would be a seamless fallback/takeover. But that should be solvable. It might be so easy as to use a relè and when a certain RPM is reached power up rc esc and power off the sensored controller.
No .. I cant think of a situation where you can run 2 off the shelf controllers driving the same motor without also having the need for addition electronic hardware...
There are some e-bike controllers that already do this .. start in sensored/non-sensored mode then from x amount of rpm the sensor signals are ignored so then becomes sensorless.
Edit: one major plus that could be done is with rc controllers and that is to just add sensor inputs to the controller and in the firmware just have the option to use them or not... this would one of the problems solved for ev use...
Also the use of a device such as a CA that can make open loop control become a closed loop control and this will take care of the other issue with using a rc esc on a ev
