what about 2 ESCs, one for each termination? With these tiny COntroller that could make sense, and, although I'm not an Electronic expert (my skills and know-how are amazingly increasing, though), Couldn't see any major issues to do that other than a bit of work for an actuator and the extra cost for another esc. Even the total Heat amount would be shared by the 2 and different programming on the castle software could be done....
Well, sure the same could be made with a single ESC, that was just an Idea, no doubt an option that has been yet covered on ES...
Also, I've only experience with the 4t motor, and real world datas are the best....but working on theory and numbers, seems to me that the 4t in wye is one of the best config to get the the 7Nm peaks that this incredible motor is able to push out, running them at 12s....
What could change the perspective would be to run them at higher voltage I think....A 6t in wye At 72v sensored should be better for the same purposes, and a 4t at that voltage (maybe water cooled and with some work on the Controller side), in wye, should fly enough to not need any re-termination and maybe even gears (for my needs). At 75v My bike should be able of almost 80Kph.....I think.
