casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,047
Ok. Curious to see your changes. Waiting for our pull requestkaziq said:The official one: https://github.com/OpenSourceEBike/OpenSourceEBike.github.io
I think is better to follow the documentation, git can be complex enough to not follow some documentation / examples.kaziq said:But that was my point that I don't know how to do a pull request
In the git doc they say I have to commit my changes to an online repo, then call git request-pull giving that repo URL as the parameter. But isn't there a simpler way?
Done. Thanks!kaziq said:Okay, managed to fork, and committed my changes. You have the pull request pending.
There was an app but is not updated anymore, it needs development which no one is doing.Deadrabbit said:Hi,
i have (maybe) a stupid question which i couldn't answered by myself reading the entire thread:
Is there a android app, which is working with the display?
@casainho wrote in his first thread, there is a app. Later, he wrote, that there is no app.
Thanks!
BW
That app would need some development work.erlano1977 said:Hello,
if this mobile app from this project:
https://github.com/OpenSourceEBike/TSDZ2_wireless/releases
could still be used, that would be really great.
Excuse my English, it's not my mother tongue.
casainho said:That app would need some development work.erlano1977 said:Hello,
Why would that app be important for you? Can you explain how would use it / why / in what situations?
I almost sure the firmware version you use is not compatible with the display. The display is compatible with the TSDZ2 firmware I developed but that I did not updated anymore since long time ago. Maybe you can ask to that firmware developers to support the display, that would be the best for you.erlano1977 said:casainho said:That app would need some development work.erlano1977 said:Hello,
Hello,
Thank you for your quick reply and for sharing your development work
Firmware for the TSDZ2.
I had 2 drives (TSDZ2) for my wife and I's bikes
Built into existing wheels.
I came across your project while looking for customizable firmware for the TSDZ2.
I already have my motor on their firmware: https://endless-sphere.com/forums/viewtopic.php?f=30&t=110682&start=1225
Changed with the Java Configurator. Works flawlessly.
Thanks again for the manageable program.
I'm currently using the VLCD-5
which unfortunately a little without their configurator for setting the parameters
is restricted.
For that reason, I would like their alternative, the: EasyDIY OpenSource Ebike Display
rebuild what also I believe no restrictions
Regarding the compensation of the data for the kilometers driven, as in the case of the VLSD-5.
The open source ebike display is not very big, but for normal use,
it is enough.
To set the parameters, the Ap would be the crown for your project.
Besides, the Ap wouldn't be bad for my 61-year-old eyes either.
I also use this BMS:
https://www.lithiumbatterypcb.com/product/6s-7s-8s-10s-lithium-ion-or-lifepo4-battery-29-4v-42v-33-6v-29-2v-smart-bluetooth-bms- with-rs485-and-uart-communication-function/?attribute_specification-selection=10S+li-ion+30A+with+UART+%26RS48
in connection with an ap, which the friendly user documents very well here:
https://www.youtube.com/watch?v=9ch9p02x7BU
maybe you could integrate the data from the BMS.
I have another question regarding the Oled display.
I would like to use this one: https://www.ebay.de/itm/272245860631
And run it over SPI, since you mentioned that the displays over the SPI interface
would run smoother.
Is this display compatible for your project?
I had already printed a 1.3 inch case according to your file (thanks again),
but then had to realize that it was too small for the display specified above.
I will then scale it to fit.
for information here is a comparisoncasainho said:I almost sure the firmware version you use is not compatible with the display. The display is compatible with the TSDZ2 firmware I developed but that I did not updated anymore since long time ago. Maybe you can ask to that firmware developers to support the display, that would be the best for you.erlano1977 said:casainho said:That app would need some development work.erlano1977 said:Hello,
Hello,
is restricted.
it is enough.
would run smoother.
And yes, the OpenSource display is small and that is the way I like it. There are the other big displays as 860C for the ones who prefer bigger ones with color.
Yes, this cheap OLED displays are kind of old OLED and are not very good at outdoors. The best display I would like to try is an eink fast refresh one.SUPERJC said:for information here is a comparison
On the ESP32 there is a small TFT display
I tried both oled and TFT
TFT is better in daylight outdoors
would have to find small TFT displays to try
about BMS:
https://www.birdandgua.net/bird/2021/07/%E5%AE%B6%E7%94%A8%E5%84%B2%E8%83%BD-powerwall-diy-%E7%AC%AC%E4%BA%8C%E5%9B%9E%E4%B9%8B-bms-%E5%A5%BD%E5%A5%BD%E7%8E%A9/
We can not access to the same good quality screens as Garmin.SUPERJC said:You can add Sun visor
The TFT display is small and very fast workingcasainho said:We can not access to the same good quality screens as Garmin.SUPERJC said:You can add Sun visor
But if you are using a Garmin, why do you use your display? Wouldn't be better for you so have a micro display as the OLED 0.96 inches display and then that big Garmin display??
Hi, recently I had the same problem, BTS4140N is not available anywhere (I ordered some from Aliexpress, but they never came).dustybicycle said:Would you be able to suggest alternative components for the BTS4140N power switch, and the BSP296 / BSS123 transistor? All of the major electronic component suppliers have no stock.
Are you sure you flashed the correct firmware version for the display??kaziq said:I decided to flash the OS firmware to test the display, and the modified transistor circuit works fine. The motor powers up, and works
I have one problem though with the OS display:
The image seems to be shifted up by two pixels, and there are two lines of garbage on the bottom.
The lines are visible from the very start, and even if the motor is not connected.
How can I get rid of that?
Yep, just reflashed 1.3" SPI to make sure. The lines are still there.casainho said:Are you sure you flashed the correct firmware version for the display??
And isn't that the 0.96 inches display?kaziq said:Yep, just reflashed 1.3" SPI to make sure. The lines are still there.casainho said:Are you sure you flashed the correct firmware version for the display??
Nope. Definitely 1.3 inch.casainho said:And isn't that the 0.96 inches display?
Both 1.3 and 0.96 SPI produce the same output. With I2C versions the display stays black, and the nRF board does not seem to start (led stays red).casainho said:Anyway I would suggest you to flash all the 4 versions, just to see how things happen.
