Cyclomania
So I have this fatbike frame where the axle is too broad too fit an old bbs02 motor I have.
Is the only way to fix this problem to get one that is 120mm(as the axle also is) or is it possible to get some sort of spacing that could connect to the pedal on the other side some other way?
Also, I wonder if someone has cut their axles with for example an angle grinder to make it shorter? And if that worked or just gave rise to other problems?
Looks like the picture.
Bet regards
Bet regards
