parajared
I am a non-BMS user and I have taken an interest in keeping my LiFePo4 pack alive and well.
As we all know, stuff posted on the internet is always undoubtedly true and we should never really suspect its accuracy; however after perusing the boughs of the internet I have come across several claims about LiFePo4 that are in complete discord with each other and I’m just not sure which claim is right.
For instance it’s been widely said that LifePo4 can be damaged if brought above 4 volts but…
1.
A) “Trickle charging a fully charged cell for hours on end even if it's voltage never exceeds 4 volts will damage it.”
B) ”So long as the cells don’t overheat and there isn’t enough amperage to overcome the internal resistance of the cells to reach 4 volts the cell is totally fine.”
Or…
2.
A) The only way to identify when a LiFe cell is out of balance is during discharge. You need at least 1c discharge to see the differences.
B) You can identify out of balance cells by checking either the resting voltage or charging voltage of each cell.
Or…
3.
A) Discharging to 100% is just the same as discharging to 50%. People just discharge to 80% to keep out of balance cells from dropping below 2 volts. You would get 1000 cycles out of a 100% DOD pack and 2000 cycles out of a 50% DOD setup, so really just the same amount of energy.
B) Discharging a pack below 80% prematurely wears out the battery regardless of whether the cells dropped below 2 volts or not.
1.
Or…
2.
Or…
3.
