donob08 said:
Jeremy
That is a great and consistent explanation. I see that you think of the “Current Multiplication†as the Motor Current being a multiple of the Battery Current. I’m not sure that others had the same meaning. From your description, the motor current falls with decreasing throttle position or lower PWM. I don’t think that is what some mean by current multiplication. I think some believe that current increases as PWM duty cycle becomes smaller..
There are, for sure, issues around saying at 50% PWM the motor sees 50% voltage. Yes, that’s the average voltage, but the voltage is really full voltage 50% of the time and 0 for 50%. I think it is these changing states that have people worried about what they describe as Current Multiplication that contributes to controller heating at reduced duty cycle.
I, for one, don’t think current in an inductor changes quickly. I do think trying to turn off the current to an inductive load is going to cause problems. I think the problem is that the controller must “sink†the inductive current during the off cycle. While the current is just the same as it was during the ON cycle, for low duty cycles this “sunk†current exists more of the time than the productive current. That leads to more heat than light. I mean more heat than propulsion.
I think you like debate.
Don
I was deliberately trying to keep things simple by only considering a single condition, a bike at a steady speed on level ground. If, for example 3 above, the bike was going up a hill, facing a head wind or accelerating then the current for 25% throttle would be higher, in fact as high as the motor wants in order to try and keep the motor at the speed that the throttle setting was commanding. Its quite probable that, for a system like that above that's capable of delivering 800 watts, the motor could try and deliver 800 watts at 25% throttle, if the torque demand from the load was high enough. The battery current would still be 16 amps, but the motor current would have to be 64 amps to deliver the needed torque.
The key thing here is that, for the non-current limiting case, there is a tight relationship between battery current and motor current for a given power and throttle setting. At 25% throttle (so 25% duty cycle on the PWM, for the non-current limiting case) for a given power the motor current will be four times the battery current. For half throttle at the same power it will be twice the battery current, etc, etc. As soon as the current limit kicks in this relationship breaks down, as the controller will reduce the throttle setting (in effect) to limit power. As before, this is heavily caveated by my assumption that, to simplify things, we're dealing with perfect parts, but the core principle still applies with real components.
This relationship between throttle setting and current ratio is important. I'm sure people here have read of non-current limited RC controllers popping at low speed, part throttle. If you try and baby one of these off the line, with just a tiny throttle setting, then what you're really doing is forcing the controller to deliver very high peak current pulses to the motor. AFAIK, these things don't have any form of current limiting, so if, for example, you had a 50V system, decided to only open the throttle 10% at start up and had a start up power requirement of 800 watts to get the bike accelerating, then although the battery current would be a nice, safe, 16 amps (at 800 watts) the motor current would be ten times this, 160 amps. It may be that just whacking the throttle open wide is the best way to try and prevent a non-current limiting RC controller blowing up, as at least this will keep the current multiplication under control. Its all just theory, though, and may produce other, more spectacular side effects....................
Jeremy
