:lol: yah ice it's a fat tire too so more drag also
telsan I think this is why wesnewell wasn't getting as much speed also, but he was/is running 100v 45amps.
just not enough amps to get even close to the no load rpm with the big ash wheel!
Speaking of, what was the kv for the 3000 mxus 4t v1?
I scimmed though the first 7 pages again in the original thread and couldn't find it.
Just got the the CA v3 with the pot attachment from grin today
once I get that installed and figure out why my laptop is not populating the controller in the dropdown menu in the xpd program, I'll be upping the amps to see if I can get closer to no load rpm. With the thermal roll back of course.
John always happy to have you drop some knowledge my way.
I'm about 170lbs soaking wet. But with the steal frame, the 25lb motor, 31lbs of 22ah 18s lipo (soon adding 13lbs of 16ah 18s multistars), and the gas engine, tank ect estimated weight ~25lbs (soon to be removed after some testing) The weight adds up quick!
I think the Ideal solution to building a fat tire ebike would be mid drive.
A stout big block ~15kv, output shaft spinning counter clockwise with a 48v battery. Would bolt right up to my existing jack shaft kit.
Boom Done!
Or a ~20kv on 36v.
This is about 700rmp. I figure this would work good since the gas motor runs at 500-600rpm max.
Does anybody know if one of these motors exist and have a link?
Anyway I think 42mph is fast enough (probably too fast) on tires that are probably designed to go 30mph max and say max 30psi on them. And no suspension.
I'd like to try out the widest 21" moto rim they make with the biggest tire for it. This will at least drop the OD quite a bit. Might look a little goofy but I would feel a lot safer going 50mph.
