improving MXUS 3000 V2
Madin88,
Great work on the inside of the covers. It should add good turbulence and velocity at the copper for a higher coefficient of convective heat xfer from the stator to the inside surface of the shell. You increased the surface area too, so that moves the heat to better to the outside surface.
What do you plan to reject the heat from the outside surfaces? The options without opening the motor to the elements are:
1. Increase surface area.
2. Increase flow velocity and/or turbulence at the surfaces. 2 ways to do that are, blades on the outside which add surface area too, and using scoops or ducts to direct more air toward the motor.
FWIW I've been working with the factory of my motors for better heat xfer. Using a similar "dry" approach as yours, along with all of the on the exterior, we're conservatively estimating at least a 30% improvement in heat xfer for their scooters. That's a huge benefit in that market, because power is a primary selling point.
John
thanks for the tips John.
i think first i will leave the outside as it is because on my cromotor it never was hot to the touch. as example 100°C on the windings and only 30-40°C on the sidecovers.
once i burn my fingers i will think of that. what i bother about is if the fan will keep its form at 100-110°C. can it withstand or will it melt?
another thing which would be helpful is white colour at the outside. while black colour absorbs almost all radiation heat from the sun, white only soaks up about 20% which would be very helpful in summer and also in winter if its sunny :)
for motor inside entirely black would be optimal (sure only very thin coating otherwise it works more as an insualtion).
The final step to heat xfer is from the outside surface of the shell to the outside world. If that remains unchanged more heat can be moved only if the shell surface is hotter. Your effort so far will get the exterior surface somewhat hotter, just like the oil fill guys see. That will help with intermittent use, but also just like the oil guys see, at significant continuous performance the improvement is small.
Increase exterior surface area and/or direct more airflow at the motor, and it will move the same amount of heat at the lower temperature and more heat at the same temperature. I'm of the opinion that motors should be opened as few times as possible, so when I open a motor I do everything I can think of including the kitchen sink, and close it only to be opened when the bearings wear out. Those magnets have they're coating for good reason, and unless you've figured out a way to prevent the stator from scraping them during disassembly and assembly (please let me know if you figure that one out), then some damage is down however slight.
John
Any body know where I can get the hall sensors?
I thought I was being very carful not to bend the wires a lot, but today just after I got the bundle through the axle I noticed one of the hall wires broke clean off the sensor. :evil:
Then I saw another wire on the middle hall was broke too.
V1 mxus 3000
thanks
Are these the one's that come with it?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&sqi=2&ved=0CEMQFjAB&url=http%3A%2F%2Fwww.mouser.com%2FProductDetail%2FHoneywell%2FSS41%2F%3Fqs%3D%252Ffq2y7sSKcK%252F%25252bhfJuO3wrA%253D%253D&ei=JRfsVJrjFMGfyASR2YDgAg&usg=AFQjCNF9fp247LRuuHNBQxroEhN5wj446Q&sig2=6WfPDKn0zqcEVVsyxcPmqw
I seen earlier someone mentioned upgrading to ss41a's.
Any thoughts?
Last time I needed some I ordered them from lyen.
http://lyen.com/ - he has the ss41's for 3$ a pop. prob a bit expensive , but at the time did not want to deal with possibly fakes.
Sorry I jinxed you and you ended up an example of the dangers of opening motors. I only had to mess with halls once, but after failed attempts starting with raw halls (I'm no good on fine soldering), I went with Ebikes.ca . Then you know definitively you get good ones, and they come pre-wired. Support our forum host when you can.
For phase wire upgrades, I've had the most success using 18ga magnet wire. That way I'm bringing one round wire bundle out of the axle with 4 layers of protective insulation, and the very high thermal limit of the wire coating on the insulation between phases. Stiff wire coming out of the motor is a non-issue in my builds, and I can convert to normal wire at the drip loop or anywhere up to the point that flexibility is needed.
When I crashed and mangled HubMonster's 6 phases into a single rats nest of copper, I tried to duplicate the factory's harness of 6 wires, the metric version of 10ga which is just under 10awg, but there was no way I was getting it thru the axle. That was without the fiberglass material outer sheath (or whatever that white fabric tube is they use). With the magnet wire I was able to get 9awg worth thru for the 6 phases.
The biggest pain in the ass about that route is being absolutely sure each has continuity end-to-end, so the outside ends are only taped until motor is assembled, and I check continuity multiple times during the process and take due care not to scuff the magnet wire varnish only to end up with a phase short down the road. Having to check continuity and better use of space are reasons to go with a nice size magnet wire.
John
madin88 said:
make sure the sealing ring does not chafe against the wire. i have removed the stock lock ring (very sharp and big risk of short circuit!!) and used a zip tie instead
Damn man, just saw this thread and I already did what you mentioned today already.
That stupid ring already damaged outside of my cable so then I was wondering for about half an hour what to do with it and later replaced it with zip tie.
But I am still kind of worried about how damaged cable could be on the inside so upgrading wires is a must now (for me to sleep better at least).
And a question: did you leave stock bearing seal in there?
BTW: I also laced up the motor with your spokes today :) (still needs truing)
I did not change the bearings or additional sealing ring on the 4T motor. all stock.
on the 3T i will install FAG brand bearings which seem to have tighter sealing rings.
pleased to hear the spokes did fit :)
To prevent spinning parts from damaging the wiring harness, I used to use zip ties, but they break and the zip head gets in the way. It's 18ga magnet wire to the rescue again. I can wrap it semi tight and push into small places for final tightening. I keep the 2 ends from shorting so I don't end up with a coil that I'm passing all that electricity through, though I don't know if that's important or not. I've never had that method fail, and some are over 5 years old.
John
Justin said he didn't carry the prewired halls anymore but he sent me a link to some.
I just ordered 10 because that was where the price break was.
So I'll have plenty for boo boo's. :|
Might use the extras for brake switches too.
Read somewhere on here of someone using halls and little magnets they drilled right into the brake handle.
Works for brake light switches too.
okay got the two replaced and went to do the third.
But it's being a stickler about popping out of it's slot.
Is it appsolutely necessary to replace all three?
The wires on the third are holding up well.
http://www.digikey.com/product-detail/en/SS41/480-1999-ND/701354
this is the link Justin sent me.
well I just tried the motor and yep that third hall is no good.
motor chugged then one time didn't move. gave it a spin and it chugged again.
I must have broke it trying to pry it out.
I'll be replacing that one tomorrow.
At least I just have to pop one cover off.
when i got my motors i noticed the hall sensor in the middle was about 2-3mm below the surface. check it. maybe this has a bad effect on performance..
just got done test riding! Woo! This thing is fast!
But I thought for sure I'd be able to go 50mph, I only got it up to 42. :lol:
That's fast enough for me.
That's 64.1 batt amps 119.8 phase amps. 18s lipo charged to 4.1v per cell. On 120% throttle
So yah it was that last hall.
I had to chip away at it with the flat head, sucker was really glued in good.
phase wires are 12 awg then 10awg once they get outside the axle.
What's the highest battery amps I can set the 18fet 4110 Infineon to?
Also what is the max phase amps do you think I should go?
Highest batt amp i have used on my 18 fets 4110 was 100A and 250A phase with max speed set to 99% ( not 100% because this is to avoid mosfet blow)
above 40mph what will limit your speed if you have the right motor turn is the batt amp.
Doc
Doc
Its good to know this information. I was thinking about maxing out my setup at 18s and I can still get 40mph. Thats good enough to do what I want. Thanks for this info. Im running 65A battery which turns out to be 80A and 170A on the phase.
Doc
Doc
Do you mean this is a setting on your controller? Why does the 1% margin save your controller from blowing?
