solar well done, you get an award for that.solarbbq2003 said:chip info
http://www.infineon.com/cms/cn/product/ ... 5ce2eb6a27
Geoff
Jeremy Harris said:Have you guys got a different chip in your Infineon controllers? Mine appears to be an XC846, not an XC864.
hi sorry about that. I said about the +12v going to ebs+ on the board a closeup of the underside of your 15fet where all the markings are would help to clarify things.John in CR said:That's why this is the "Dummy" thread.
I saw the XC864 and figured you guys were just talking about yet another infineon controller.
Also, in reference to an earlier post, someone mentioned +12V going to the EBS pin, apparently for brake lights to also cut the controller output. My 15 fet Infineon with controllers with XC846 MCU's come stock with a single wire for brakes. The factory guy tells me that wire expects 12V, but it is connected to the BK pin, not the EBS pin.
Also, in the other infineon threads mention is made that the regen limit is 60V. My controllers are 60V controllers, so is that standard 60V a hard limit, or would it work for 60V nominal (ie a 71-72V peak)? I realize you guys are confident and probably think "just give it a try to find out", but with me a negative result will have zero meaning.
John
by bobmcree » Fri Nov 30, 2007 4:10 pm
on the throttle input stage in the crystalyte controllers there is an op amp that subtracts a volt from the throttle signal and then amplifies it so that 1-4v from the throttle is turned into 0-5v before it is fed directly to the soft start cap on the pulse width modulation chip. the output of this chip is fed to a logic gate where it is combined with the motor drive pulses to achieve pwm control of the high side fets. the low side fets are just turned off and on.
the pwm chip is designed to be used a bit differently than the way the crystalyte designer implemented it. there is a feedback amp in the chip that could be used for current feedback to get better motor control, but instead they used that circuit for low voltage cutoff and current limiting. as a consequence, the output of the pwm is directly proportional to the voltage on the soft start cap. the conditioned 0-5v throttle signal is applied directly to this cap, and the ebrake can pull down the cap voltage through a diode. the cycle analyst pulls down the ebrake signal to achieve power limiting, as does the current mode throttle design fechter posted.
reducing the value of the soft start cap which is connected to pin 8 of the ka3525 pwm chip will speed up the ramp up of the pulse widths under all conditions, including the one where you switch the unit on with the throttle stuck on. playing around with the throttle voltage as a function of position can change the throttle response curve a bit, to make it more linear.
when looking at the voltage on this cap be aware that there is an internal circuit on the 3525 that can pull it down when the shutdown signal is asserted on pin 9 by the circuit that tells it the motor is not turning. this can be confusing at first. if you reduce the value of the cap too much you can let the pwm go to full on before the controller "realizes" the motor is stalled and blow a lot of fets as a result. be cautious.
