BMI
You are absolutely right Malcolm. The last thing I also want is for the thread to get locked up so it is probably best that I don't rebuke Mr Harmon with answers to his comments and questions. I am more than happy to answer all of his concerns and certainly have several emails on record from Lifebatt customers who I have helped out (and we are not just talking about e-bike customers exclusively but all customers).Malcolm said:Before this thread turns into another slanging match and gets locked, can anyone give me a sound technical explanation why these cells are not recommended to be installed vertically?
If the forum moderators can guarantee the thread will not be locked I will come back and answer in full. But for now that is the last I will say on the matter so as to not provoke Mr Harmon into a full on slanging match which is not helpful to any of us.
Malcolm I have not been provided by any directive or other instructions from the factory stating that either the loose cells or HPS or SB battery packs must be operated so the cells are kept horizontal. In fact my BMI engine start battery in my own Toyota Camry is installed on its side since it fits better this way as you can see from the attached photo. It has been in my car operating this way for just over a year and starts my car everytime, day in, day out, without fail and without any signs of "cell/electrolyte creep" or any other name this so called phenomenon is called. I have even used a small piece of timber as packing since the BMI LiFePO4 battery is considerably smaller than the original lead acid starting battery (one day I will get around to making a proper bracket).
If Mr Harmon chooses to not provide any waranty for Lifebatt HPS battery packs if they are used in any orientation other than horizontally that is his choice and there is no argument from me. For customers who want to use a BMI HPS battery fitted to a bike, car, boat or any other application horizontally, vertically, inverted (or anywhere in between) that is fine by me and the same full warranty will apply when used in any of these orientations.
We can also consider the case of other LiFePO4 cells. For instance even though they are considerably smaller, A123 M1 cells are similar in construction to BMI and Lifebatt cells and also feature a fully laser welded case.
I have seen some pretty wild aerobatics manoeuvres performed in model RC helicopters powered by A123 cells and never have I seen or heard of a case where the helicopter has dropped from the sky because of "electrolyte moving around in the cell"!
Even for their intended application in Dewalt power tool packs a cordless drill being used on a construction site would often be used with the cells in the battery pack in orientations far exceeding the horizontal plane, eg. when drilling or screwing into a ceiling or roof. I have never seen any Dewalt power tool instructions state that the battery pack/power tool must only be used horizontally.
So I don't believe micro13car should be too concerned about the orientation of the cells used in his custom assembled battery pack.
Enough said.
