BatteryKing
- Joined
- Feb 21, 2009
- Messages
- 37
I am regularly going 20 km one way at 50 kph much of the way. I normally use around 10 Ah on a 48V HPS pack, but sometimes use 12+ Ah. (I am a big dude.) I also live in a Republican town, so of course the roads are in horrible shape and I have actually been having problems breaking 12G spokes. (Frequent tune ups are a must.) I figure for a real configuration, you need to calculate for loss of capacity over time, avoidance of 100% discharge on the normal route, and buffer space if you need to take a detour (a likely detour for me is an additional 7-8 km away up a hill), so 48V and 20 Ah seems proper for my purposes. Peddling this thing back the other way is quite a workout!
It seems in order to go to a lower CG with this pack like what Micro Car is doing would be quite an endeavour for me because I would need to have cells all over the place. Trying to go around this by lower voltage would mean less speed, but 20+ km can be a long ways at lower speeds when I have somewhere I need to be (like work). Then Ah goes in 10 Ah increments with these cells and I am already doing 10+ Ah on a trip, so it seems unwise to scale this back.
A thought to cross my mind is to double saddle batteries on either side of the luggage rack and have padding because smacking batteries into concrete isn't the best of ideas as I have noted before and padding would at least mitigate the shock. I also like the idea of using a recumbent bike because in theory at least you should be able to free up the space under the bike for a battery pack and you should be more aerodynamic granted that you could get the right frame configuration and route the chain around the battery or something.
