lemmiwinks
G'day!
I've got an EVT 168 which is currently running 4 50Ah SLA batteries (approx 14kg each for a total of 56kg for the pack). I'm wondering what Ah capacity LiFePO4 battery I could replace them with? I'd go for a drop in replacement something like this:
which happens to be a 20Ah unit.
Would 20Ah LiFePO4 be comparable with the capacity of 50Ah SLA? The range I have currently with SLA is fine for the use the scooter gets, I'm not looking to increase that, but if I can get the same range and cut the weight of the battery pack from 56Kg down to 11.2kg I'd be pretty darn happy.
According to the website they're made from a bunch of 18650's and a BMS but it doesn't say if I need a special charger or not. The EVT comes with a 3 stage 48V charger (actually I suspect it charges as 2 24V strings, but I've not 100% verified that) for the SLA, does anyone know if these can be used with LiFePO4, are the BMS that good? What about battery equalisation? Using PowerCheq's right now but I know they're not needed for lithiums, so can the BMS take care of that too or would I need a separate 12V charger for each LiFePO4 pack?
Sorry for all the dumb questions.
Cheers.
Cheers.
