This is your size: http://www.gasgoo.com/showroom/autowb/auto-products/1178656.html Samples free 8)speedmd said:Wonder if these slinky type cores are available in standard sizes for prototyping.
Honk said:Seems you have used mostly good materials and a well optimised design solution.
It could be that a commercial design like this is simply not economical to produce.
Yes. The motor was designed as part of this system. Two reduction stages (including the one to the wheel), with a 2 speed gearbox integrated into the jackshaft. The 2 speed components only add 600 grams to the jackshaft assembly weight.....(less than that if you take into account the fact that the gearbox has integral freewheeling, so a separate freewheel is not required).crossbreak said:Are you still planing on going two stage with the (ok still simulated) figures you got? Single speed would be OK for most people who go offroad i guess. just spend more $$$ on the motor and save the $$$ and kilograms of the 2-speed gearbox.
Thanks for the info. Given that they are designed to operate at around 1000hz, that makes sense... There wouldn't be enough gain for me to justify the extra cost for my motor, though, unless I wanted to run it a lot faster.......toolman2 said:btw miles, joby seem to now be using .13mm lams, pm me if you want more info.
Miles said:The 2 speed components only add 600 grams to the jackshaft assembly weight.....(less than that if you take into account the fact that the gearbox has integral freewheeling, so a separate freewheel is not required).
Constructing a helical core for my motor would require a strip over 40 meters in length, with 3600 slots in it..... Forming it into an accurate and stable cylindrical seems a pretty daunting task, too......bearing said:The spiral/helical/slinky process seems like a good idea for high volume production. But not for prototyping, of course. And probably not for low volume production either.
I've been working on this gearbox design for 7 years. I've considered everything.......bearing said:How about making the gearbox able to go into neutral, or the freewheel able to lock?
Then you are able to use regen.
Miles said:Constructing a helical core for my motor would require a strip over 40 meters in length, with 3600 slots in it..... Forming it into an accurate and stable cylindrical seems a pretty daunting task, too......bearing said:The spiral/helical/slinky process seems like a good idea for high volume production. But not for prototyping, of course. And probably not for low volume production either.
